Enter Search String Field
You can enter your search criteria in the Enter Search String...
field.
Tip: Use AND, OR, <, >, operators to refine your search.
After you enter your string in the search field, the Results Browser
will only be updated with your search results when you:
- Press the Enter key.
- Click the magnifying glass .
- Use the Add as Filter option in the Entity Editor.
