The Extract Solver Deck Data tool allows you to import a HyperMesh exported input deck and extract the include hierarchy assembly
information from the HyperMesh commands HMNAME,
HMCOLOR, and HMASSEM.
By extracting these data, HyperView applies the attributes to
the current HyperView model.
From the Tools menu, select Extract Solver Deck Data to display the
dialog.
Figure 1. Extract Solver Deck Data dialog
The solver input decks supported by this tool are Abaqus,
ANSYS, LS-DYNA, Nastran, OptiStruct, PAM-CRASH 2G, and Radioss. For ANSYS solver decks, only the assembly information is extracted.
A HyperView component set (group) is created for every assembly
in the input deck; this allows HyperView sets to accommodate
components (parts) that belong to more than one assembly.
Note:HyperView sets that are created are not hierarchical groups. If an
assembly contains sub-assemblies and a nested assembly structure, all the components of
all the nested assemblies are gathered and added to the HyperView set.
Extract a Solver Deck Assembly
Data.
From the dialog, select a format from the drop-down menu and select the
Assemblies check box.
From the file browser, select a HyperMesh deck that you want to import.
Click Open.
Click OK to close the dialog.
HyperView extracts the assemblies, colors,
and labels from the HyperMesh file and applies them
to the active model.
Extract the Include Hierarchy from a Solver Deck
Data.
Includes check box.
Click Open.
HyperView extracts the include hierarchy and
displays it in the Results Browser.
