Visualize Modal Deformation, Stress, or Strain Contours
  1. From the Plot tools, click the Contour tool.
  2. Select the appropriate Result type and the direction using the drop-down menus.
  3. Click Apply.
    Note: The Stress or Strain results in the flexible body will be available if Stress or Strain was requested while generating the flexible body.
