The Command Sets panel allows you to edit command sets for the solver-command file. The
command sets for a model are order dependent, since they define the contents of the solver
command file.
The panel options change depending on the command set type selected.
Figure 1. Command Sets Panel
Note: Command Sets cannot be created through the GUI. Command Sets can be defined by editing
the .mdl file. Refer to MDL Command Set Statements for details.
