Creates a 4x4 horizontal or vertical page layout that displays a series of frames for
up to four media files at specified time offsets.
From the Media ribbon, click the Filmstrip tool
to display the panel.
Filmstrip layout
Select Horizontal or
Vertical for the filmstrip layout.
Files
Use the file browser button to select up to four media files to be
displayed.
Offset between frames
Each successive window is offset by the amount entered. Negative offset
values are not allowed. MediaView voids any invalid
entries and resets the value to the default.
Fit image to window
Scales the video image to fit the image in the area of the window in
which it is contained.
Time Scales...
Displays the Synchronize Animation dialog. Use this dialog to
synchronize windows that contain animation results in different units
and/or begin at different time steps.
