Create waterfall plots from XY force response data and input pulses.
From the 3D Chart ribbon, click the Waterfall
tool.
If a waterfall plot exists in the current window, HyperGraph 3D automatically populates the default values.
Otherwise, you can enter information into the panel's fields.
Plot Type
Select a waterfall plot type from the first drop-down menu. Options include:
Frequency
Default.
Order (scaled)
Calculates orders by scaling the frequency values by the input magnitude
values.
Order (resampled response)
Modifies the time values of the response curve so the FFT returns order
instead of frequency.
Order (variable DFT)
values. Uses a DFT with a varying sample size to ensure a consistent
density of points along each waterfall slice.
From the second drop-down menu, select:
Time
Default.
Input magnitude
Instead of plotting against time, plot against the units of the input
curve's magnitude (RPM, RPS, driving frequency, and so on.)
Note: If you change the Plot type settings, HyperGraph 3D updates the From and To labels on the far
right side of the panel to match your selections. These fields are displayed
when you select Show advanced parameters.
Data Curves
The Response curve can be defined by following these steps:
Click the curve selection button, ,
in the Response text box to display the Response dialog.
Choose a curve from the Curve tree and click
Select.
You can also click Preview to view the curve in the
Preview dialog before selecting it.
Click Close to close the Curve dialog.
OR, select one of the following methods:
Select the curve from an XY plot window.
Enter the PWC math reference and press Enter.
Press and hold Shift and left-click on the
curve.
Input
Select the input vector used to generate the response vector and press Enter. Input curves can be selected in the same way as Response
curves (see above).
Input vector is in RPM
Select this option to scale the response curve by 60 to use RPS.
Waterfall Slices
Number
Enter the number of samples.
Step size
Enter the step size. A sample will be taken at each step increment.
Contour waterfall
Display a contour on the waterfall plot based on "Z".
For each of the following parameter fields, select an item from the drop-down menu.
Click Apply to apply the parameters.
Sample size
Number of data points to use in each FFT.
Window function
The windowing function for FFT.
Amplitude type
Peak, PSD_RMS, or Auto spectrum.
Amplitude scale
None, DBA, DBC, DB4, or DB.
Show all options
Select this option to display additional parameters.
Summary and Frequency
The following parameters are displayed if you select Show all
options.
Summary
Freq resolution
Twice the delta frequency returned from
"freq(response_curve.x)". Or, the third point minus
the first point returned from the frequency calculations.
Nyquist freq
Half the maximum value returned from
Max order
The Nyquist frequency divided by the maximum value in the input curve’s
magnitude.
Number of points
The number of points in the Response curve.
Time increment
The delta time in the Response curve or the difference between the first
two points of the X axis in the Response curve.
Frequency
From/To
Two sets of From/To fields are displayed at the far right of the panel.
The headings above From/To change depending on the Plot type options
selected. For example, if you select Frequency and Time, those headings
are displayed above the From/To fields. If you select Order (scaled) and
Input magnitude, those headings are displayed. For any option you select
under Plot type, enter the desired range in the From/To fields.
Apply
HyperGraph 3D creates or modifies the
waterfall plot based on your selections.
Undo
Restores the waterfall plot to its previous state.
