Mount Optimization - Load Tab
Enter the powertrain and mounting configuration data manually or load the data from a configuration file. Mount stiffness can be static or non-linear.
The data supplied is used to calculate powertrain rigid body mode frequencies and
kinetic energy distribution.
Figure 1. Mount Optimization Utility - Load Tab
