Allows a component to be part of more than one assembly.
HV_ASSEM_DUPLICATE_PARTS
HyperView Environment Variable
HyperView does not allow a component to be present under
more than one assembly as it could cause some issues in results transformation. When
reading such files, those components are removed from all assemblies except one,
depending on the reading sequence.
Setting this environment variable to 1 will remove this restriction.
Examples
To set the default file type displayed in the file browser,
from the Windows Environment Variable dialog, select
Edit and enter the following information:
Upon setting the environment variable, HyperView will be
able to read the data as it is and display it in the browser.
