Create Parameter Inputs
Use the Parameters tool to create size design variables by converting existing parameters.
From the Design Explorer ribbon, click the Parameters
tool.
Figure 1. -
On the guide bar, click
The Advanced Selection dialog opens. - Select parameters in the dialog then click OK.
- In the microdialog, select how you would like to define the input values.
Complete one of the following tasks:
- Specify the lower and upper bounds.
- Specify a list of valid discrete values.
- Click Create.
