Review Exploration Summaries
Once an exploration is complete, review a summary of design variable and output response values in tabular format.
From the Design Explorer ribbon, Evaluate tool group, click the
Results Explorer tool.
Figure 1. The Results Explorer Browser opens. -
In the Results Explorer Browser, click
Summary.
The Summary shows a run-by-run summary of the exploration. The columns show the input design variable values for each run and the corresponding response values. -
From the Summary, review the design variable values and calculated output
response values at each run.
For Optimization explorations, information about conditions and iterations is also included.
Optimization Summary Data
The optimization summary table shows the design variable values along with the calculated objective and constraint values for each run.
Column Color Coding
- White Background/Black Font
- Feasible design
- White Background/Red Font
- Violated design
- White Background/Orange Font
- Acceptable design, but at least one constraint is near violated
- Green Background/White Font
- Optimal design
- Green Background/Orange Font
- Optimal design, but at least one constraint is near violated
Apply Variables to Model
Apply design variable settings from a run to the model.
- In the Summary of the Result Explorer Browser, right-click a run and select Apply variables to model from the context menu.
- In the Update Variables dialog, click Yes.
Load Results and Plots
Visualize contours, animations, and plots for each run in the modeling window.
Do one of the following:
- From the Design Explorer ribbon, Evaluate tool group, click the
Figure 2. In the Results Explorer Browser, click
Summary.
Run Status satellite icon
After submitting a simulation, this dialog will open automatically.
Note: Using this dialog, individual runs can be contoured while the simulation is still in progress. Animations are not supported from the Evaluation Status dialog.
Right-click on a completed run and select Load Results
or Load Plots.
The Results Explorer uses a full featured post-processing environment to display contour, animation, and plot results. The first-time results or plots are loaded, a second window, either animation or plotting client, is opened and the results or plots are loaded. You can add additional pages or configure your page layout to add additional animation or plotting windows as desired and load results or plots into the appropriate windows.
- Select desired result or plot options using the contour, animation, or plot controls.
Wrap Design
Create a wrapped mesh for the selected concept.
- In the Summary of the Result Explorer Browser, right-click a run and select Wrap design from the context menu.
- Optional: In the Wrap Mesh dialog, change any parameters.
- Click Mesh.
