Project
Project selected geometry onto the sketch plane as construction geometry.
Project to a Sketch Plane
On the Sketch ribbon, select the Project tool.
Select points, lines, or surfaces to be projected.
Figure 1. Select lines -
Click Plane on the guide bar then
select the sketch plane onto which to project.
Figure 2. Select plane Once the plane is accepted, the selected entities are projected onto the plane as dotted construction lines.Figure 3. - Right-click and mouse through the check mark to exit, or double-right-click.
Note: To convert a construction line to a sketch curve,
right-click the construction line and select Create
Curve.
