xy mark
Add, clear, create, delete and edit marks for a curve(s).
xy mark add type=<marktype> mark=<marklabel> <name>=<value>
xy mark clear type=<marktype> mark=<marklabel> <name>=<value>
xy mark create type=<marktype> mark=<marklabel> <name>=<value>
xy mark delete mark=<marklabel>
xy mark edit <range>type=<marktype> mark=<marklabel> <name>=<value>
Arguments
- add
- Add a mark.
- clear
- Clear a mark.
- create
- Create a mark.
- delete
- Delete a mark.
- mark=<marklabel>
- The name of the mark to delete.
- edit
- Edit the entity properties associated with the mark.
- type=<marktype>
- Select type=<entity>. The following entity types are
available:
- axishorizontal
- axisvertical
- curve
- datumhorizontal
- datumvertical
- footer
- header
- legend
- note
- stack
- <mark=label>
- The name of the mark.
- <name>=<value>
- The entity properties to create the mark on (see properties listed under add).
- range
- range =<range>. Enter the range string for the mark.
Examples
Create a mark of type curve named
"xyz":
xy mark create type=curve mark=xyz
Delete mark "xyz":
xy mark delete mark=xyz
Add a mark for the defined
range:
xy mark add type=curve mark=abc range=range="p:1-4,8 w:1-3 i:all"
