result vector color
Changes the vector color for the components or resultant by direction or value.
result vector color <direction>
result vector color by=<value/direction>
result vector color label=<RGB/label>
Arguments
- <direction>
- Define the color for the following directions: x, y, z, xyz, xy, yz, and zx. Color can be defined by entering the RGB values, a color label, or a value.
- by=<value/direction>
- Enter value or direction
as the method to define the color by.
- value
- Modifies the legend's values and color.
- direction
- Modifies the color for the components or resultant by direction.
- label=<RGB/label/value>
- Define the label by the RGB values, a color label, or a value.
Examples
result vector color y=Green
result vector color label=Blue
result vector color by=value x=Red
result vector color by=direction x=Blue
