hm_registerentitysubtypefilter
Registers an entity sub-type filter for usage by *createmarkpanel or *createentitypanel.
hm_registerentitysubtypefilter entity_type sub_type filter_value
HyperMesh Tcl Query Command
Registers an entity sub-type filter for usage by *createmarkpanel or *createentitypanel. Note that filters persist through an entire HyperMesh session unless they are cleared.
- entity_type
- The type of entity to register the filter for.
- sub_type
- The sub-type identifier. Valid values are cardimage, config, and idpool.
- filter_value
- The value of the sub-type filter.
To register a filter for properties with the card image PSHELL, prompt the user to select, and unregister:
hm_registerentitysubtypefilter props cardimage PSHELL
*createmarkpanel props 1 "Select a PSHELL property."
hm_unregisterentitysubtypefilter props
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
Version History
13.0
