Entity Types
HyperWorks entities are often used as string parameters in commands that act directly on entities in some fashion, such as creating filtered sets that contain only a specific entity type.
Below is a list of all of the entities available in HyperWorks.
These entities can be used verbatim in any command that accepts an
<entity_type> (or similar) argument.
*These entity types are specific to surfaces. Topopoints represent vertex or
fixed surface points, while topolines represent surface topological edges/lines. They are
subsets of the points and lines entity types.
assemblies | bags | beamsectcols | beamsects |
blocks | cards | components | connectors |
contactsurfs | controlvols | curves | ddvals |
domains | dvprels | elements | ellipsoids |
laminates | lines | loadcols | loads |
loadsteps | materials | mbjoints | mbplanes |
morphconstraints | morphvolumes | multibodies | nodes |
objectives | opticonstraints | opticontrols | optidscreens |
optiresponses | outputblocks | plies | plots |
points | properties | sensors | sets |
shapes | solids | surfaces | symmetries |
systemcols | systems | tables | tags |
titles | topolines* | topopoints* | vectorcols |
vectors |
