The Explorer displays a hierarchical view of your study setup
and approaches, and can be used to guide you through the study setup process.
When you create a study or open an existing study, it will appear in the Explorer. Clicking the different items in the Explorer guides you to the various parts of your study.
Figure 1. Explorer View
Study name; clicking this item guides you to study details and approach
details, and enables you to identify batch commands.
Steps to setup your study, such as define your model, input variables, and
output responses.
Steps to define approaches in your study.
Once the study Setup is
complete, an unlimited combination of approaches (DOE, Fit, Optimization and Stochastic) can be added.
Note: Additional options are included in the Explorercontext menu, such as the options to add, remove, sort,
or copy approaches. The Go To option can be used to browse study files, open the
study Directory view, or quickly navigate to the study
Setup or different approaches.
The steps you must complete while setting up your study and defining approaches
display in a hierarchical order. Throughout the study, each steps corresponding
checkbox will indicate a status.
The next step that needs to be completed.
Proceed to the next step. This step may have an optional work button to
perform tasks such as, Evaluate Expressions, Launch Post Processing and
Create Report.
Step has been completed.
An action in this step is not yet allowed.
A warning of possible changes in the step since it was first
performed.
