Edit the summary of run data stored in the run matrix by editing existing runs or
adding new run data.
Before you can edit the Run Matrix you must select
a numerical method. For more information, see Test Models.
Edit Run Data
Manually edit existing run data in the Run Matrix.
In the Specifications step, click Edit Matrix > Run Matrix.
The Edit Data Summary dialog opens.
Enter new values in each cell, as necessary.
Add Run Data
Manually enter new run data in the Run Matrix.
Click Add Run.
Enter run data.
Manually enter run data.
Copy and paste run data into the run matrix.
Example: Copy run data
from a spreadsheet, then highlight and right-click on the new runs you
added in the Edit Data Summary dialog and select
Paste from the context menu.
Tip: Add multiple runs simultaneously by left-clicking and holding the mouse
button on Add Runs. In the pop-up, enter the number of runs
to add and press Enter.
Figure 3.
Import Run Data
Import run data into the run matrix from a plain text file, an approaches' evaluation
data, or from a HyperStudy post processing file.
Click Import Values.
The Import Values dialog opens.
Select a source type.
Click Next.
Select the source that contains run data.
For Plain Text File, select the source file and delimiter type, and
select whether or not the columns in the source file have labels.
Optionally, specify the rows to import by entering the start and end
row.
For Approach evaluation data, select the approach that contains run
data.
For HyperStudy post processing file, select the source
file.
Click Next.
Define the variable to column assignment(s).
From the Variable to Column Assignment table, select a variable to
which run data will be assigned.
From the Columns in Source File table, select the column that contains
run data to assign to the selected variable.
