Constraints
Constraints need to be satisfied for an optimization to be acceptable. Constraints may also be associated with a DOE. While not used in the evaluation of the DOE, constraints can be useful while visualizing DOE results. Limits on displacement or stress are common examples.
Constraint Categories
All constraints in an optimization problem can be placed into the following distinct categories:
- Inequality Constraint
- One sided condition that must be satisfied.gj(x)≤0j=1,...,m
- Equality Constraint
- Precise condition that must be satisfied.hk(x)=0k=1,...,mh
- Side Constraint
- Bounds on the input variables that limit the region of search for the
optimum.xLi≤xi≤xUi
Constraint Types
Constraints can be defined as type Deterministic or Random (probabilistic) when
setting up an Optimization in HyperStudy, depending on the design requirements.
- Deterministic
- Deterministic constraints enable you to manually define a Bound Type, Bound Value, and evaluation source for the output response(s).
- Random
- Random problem formulations take into account the variability in the design and study the corresponding variability in the performances. This aspect is studied under reliability and robustness.
Standard Constraint Enforcement
Constraints violations can be treated in the following ways:
- Standard Enforcement
- Constraints are considered feasible when they are within a small percentage of difference between their bounds. This type of enforcement is conventional.
- Strict Enforcement
- Constraints must be perfectly satisfied with no margin. This type of enforcement may require additional iterations from an optimizer for convergence.
- Percent of Constraint Bound
- Constraints must be violated by more than this value in the converged design. Strict enforcement only uses this tolerance for equality constraints.
- When the Constraint Bound = 0.0
- In general, constraint values are normalized to their bound value. One exception is if the absolute bound value is less than this parameter.
