FKM Classification Parameters (Non-Welded)
The parameters for non-welded calculations are listed in both the Assign Material tab and the My Material tab of the Assign Material dialog.
The defaults are with respect to material = steel.
The following are the parameters listed in Assign Material tab.
Parameter Description
Effective Diameter (Deff ) Effective diameter of the semi-finished product (default = 7.5mm)
Anisotropy factor (KA ) Default = 0.9
Plastic Notch Factor – Nominal (Kp_sigma ) Default = 1
Plastic Notch Factor – Shear (Kp_tau ) Default = 1
Relative Stress Gradient X (G_sigmax ) Relative stress gradient in normal direction (Default = 0.1 mm-1)
Relative Stress Gradient Y (G_sigmay ) Relative stress gradient in normal direction (Default = 0.1 mm-1)
Relative Stress Gradient XY (G_sigmaxy ) Relative stress gradient in shear direction (Default = 0.1 mm-1)
Overload Factor (Overloading) Parameter to decide overload situation. Options: F1, F2, F3, F4. Based on the selection, the fatigue limit calculation formula may vary. (Default – F2)
Surface Roughness (Rx ) Average roughness of the component surface, (default = 100 μm)
Surface Treatment Factor (Kv ) Default = 1
Coating Factor (Ks ) Default = 1
Temperature Factor (Ktd ) Default = 1
Material Safety factor (jF ) Material safety factor for non-welded steel based on regular inspection (default = 1.5)
Load Safety factor (jS ) Safety factor defined by design loads (default = 1.0)
Partial safety factor for allowable defects in castings (jG ) Material safety factor for Casted materials (default =1, as just steel is supported)
Total Safety Factor (jD )
Total safety factor, based on jF , jS , jD and KT , D , jD = jS . ( jF / KT , D )
The following are the parameters listed in My Material tab.
Tensile Strength (Rm ) Listed in SN tab (default = 300 N/mm2)
Yield Strength (Rp ) Listed in SN tab (default = 180 N/mm2)
Elastic Modulus (E ) Listed in SN tab (default = 2e5 N/mm2)
Strain At Break Point (A%) Listed in SN tab (default = 10% or 0.1)
Normal Fatigue Limit (σ_wzd ) Listed in SN tab (default = 140 N/mm2)
Shear Fatigue Limit (τ_wzd ) Listed in SN tab (default = 80 N/mm2)
Number of Cycles at Knee Point, Normal Stress (Nd_σ ) Listed in SN tab (default = 1e6 cycles)
Number of Cycles at Knee Point, Shear Stress (Nd_τ ) Listed in SN tab (default = 1e6 cycles)
SN curve slope, Normal Stress (K_σ ) Listed in SN tab (default = 5)
SN curve slope, Shear Stress (K_τ ) Listed in SN tab (default = 8)
Fatigue Stress Factor, Fully Reversed, Normal (fw_σ ) Listed in Other tab (default = 0.4)
Fatigue Stress Factor, Fully Reversed, Shear (fw_τ ) Listed in Other tab (default = 0.577)
Constant, Technological Size Factor for Tensile Strength (adm ) Listed in Other tab (default = 0.15)
Constant, Technological Size Factor for Yield Strength (adp ) Listed in Other tab (default = 0.4)
Constant, Technological Size Factor @ adm (Deff,N,m ) Listed in Other tab (default = 40mm)
Non-linear Strain Stress Factor under bending – GJL (KNL ) Listed in Other tab (default = 1.0)
aG Constant for ( KtKf ) ratio for Fatigue Strength Factor ( aG ) Listed in Other tab (default = 0.4)
bG Constant for ( KtKf ) ratio for Fatigue Strength Factor (\ bG ) Listed in Other tab (default = 2400)
Constant For Roughness Factor, Normal Stress (aR_σ ) Listed in Other tab (default = 0.22)
Minimum permissible tensile strength constant (Rm,N,min ) Listed in Other tab (default = 400 N/mm2)
Constant for Mean Stress Sensitivity (aM ) Listed in Other tab (default = 0.35)
Constant for Mean Stress Sensitivity (bM ) Listed in Other tab (default = -0.1)
Compression Strength Factor, for tension, compression (f_σ ) Listed in Other tab (default = 1.0)
Compression Strength Factor, Shear (f_τ ) Listed in Other tab (default = 1.0)
Material Parameter Epsilon_0 (Epsilon_0) Listed in Other tab (default = 0.05)
Ductility factor (q) Listed in Other tab (default = 0)
Formulation
Current support in the evaluation build is for steel only.
Cyclic degree of utilization for normal and shear stresses:
Assessment
[ Stress amplitude / (critical amplitude/total safety factor)]
aBKx=σax/(σBKx/jD)1,
aBKy=σay/(σBKy/jD)1,
aBKxy=Taxy/(TBKxy/jD)1,
Master Assessment Calculation
aNH=12·(|aBK,x+aBK,y|+(aBK,xaBK,y)2+4·aBK,τ2)
aGH=a2BK,x+a2BK,yaBK,x·aBK,y+a2BK,τ
aBK,σv=q·aNH+(1q)·aGH1
Formulation for Static Assessment
The following process is followed for Static Assessment (non-welded):
  1. Equivalent Stress ( σV ) = Maximum combined stress across all loadcases in the event.
  2. Calculate Static Strength ( σSK ).
    σSK = Rp * npl
    Rp = Modified yield strength calculated from Size factor, Anisotropy factor and Yield strength.
    npl = Plastic support factor.
  3. Calculate Static Utilization ( aSK )
    aSK=(σV(σSKjD))1
    jD = Total safety factor.
