Stress Gradient Effect
Stress gradient effect based on FKM guideline method.
The stress gradient effect is supported for both shells and solid elements. For solid elements, the stress gradient effect is only available with nodal evaluation and for shell elements, the stress gradient effect is only available with elemental evaluation.
The Stress Gradient method is currently supported for Uniaxial and Multiaxial SN, EN with Time series loading. It is not supported for Dang Van FOS, Weld, Vibration, and Transient Fatigue analyses.
FKM Guideline Method
In the FKM guideline method, stress gradient effect is considered by increasing fatigue strength by a factor calculated using a rule in FKM guidelines. In HyperLife implementation of FKM guideline method, 6 components of a stress tensor at each time step is reduced by the factor provided by FKM guidelines.
To activate Stress Gradient effect using FKM guideline method, Stress Gradient should be set to FKM Guideline in SN/eN dialog. The equivalent stress σeq method to calculate stress gradient should be specified.
The following steps are followed to reduce stresses at the surface to take stress gradient effect into consideration.
  1. Calculate stress gradient of 6 components of a stress tensor, Δσij(t)Δz , at each time step after linear combination of stress history. z-direction is an outward surface normal. For a solid element, the gradient is calculated by finite difference between stress at surface and stress at 1mm below the surface. The stress at 1mm below surface is an interpolated stress from grid point stresses of an element of interest. In case of 2nd order solid elements, only grid point stresses at corners are used for interpolation. For shell elements, the gradient is calculated from stresses of both layers and its thickness.
  2. Using the stress gradient obtained in Step 1, a gradient of equivalent stress in the surface normal direction, Δσeq(t)Δz , is calculated in an analytical way at each time step. The equivalent stress can be either von Mises stress or absolute maximum principal stress.
  3. The related stress gradient, Gσ is calculated using the following normalization.
    ˉG(t)σ=1σeq(t)Δσeq(t)Δz
  4. Calculate the correction factor nσ(t) . Refer to Correction Factor Calculation.
  5. Apply the correction factor nσ to the surface stress tensor to obtain reduced surface stress. Apply the same nσ to corresponding strain tensor to obtain reduced strain tensor when EN fatigue analysis is to be carried out with nonlinear analysis.
    σ'
Correction factor calculation is based on relationship between n σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBamaaBa aaleaacqaHdpWCaeqaaaaa@38D9@ and G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ described in the FKM guidelines.
According to FKM guidelines, the stress correction factor n σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBamaaBa aaleaacqaHdpWCaeqaaaaa@38D9@ is determined by:
  • If  G ¯ σ 0.1  mm 1 n σ = 1 + G ¯ σ m m 10 ( a G 0.5 + R m b G MPa ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaacaqGjb GaaeOzaiaabccaceWGhbGbaebadaWgaaWcbaGaeq4Wdmhabeaakiab gsMiJkaaicdacaGGUaGaaGymaiaabccacaqGTbGaaeyBamaaCaaale qabaGaeyOeI0IaaGymaaaaaOqaaiaad6gadaWgaaWcbaGaeq4Wdmha beaakiabg2da9iaaigdacqGHRaWkceWGhbGbaebadaWgaaWcbaGaeq 4WdmhabeaakiabgwSixlaad2gacaWGTbGaeyyXICTaaGymaiaaicda daahaaWcbeqaaiabgkHiTmaabmaabaGaamyyamaaBaaameaacaWGhb aabeaaliabgkHiTiaaicdacaGGUaGaaGynaiabgUcaRmaalaaabaGa amOuamaaBaaameaacaWGTbaabeaaaSqaaiaadkgadaWgaaadbaGaam 4raaqabaWccqGHflY1caqGnbGaaeiuaiaabggaaaaacaGLOaGaayzk aaaaaaaaaa@651E@
  • If   0.1  mm 1 < G ¯ σ 1  mm 1 n σ = 1 + G ¯ σ mm 10 ( a G + R m b G MPa ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaacaqGjb GaaeOzaiaabccacaqGGaGaaGimaiaac6cacaaIXaGaaeiiaiaab2ga caqGTbWaaWbaaSqabeaacqGHsislcaaIXaaaaOGaeyipaWJabm4ray aaraWaaSbaaSqaaiabeo8aZbqabaGccqGHKjYOcaaIXaGaaeiiaiaa b2gacaqGTbWaaWbaaSqabeaacqGHsislcaaIXaaaaaGcbaGaamOBam aaBaaaleaacqaHdpWCaeqaaOGaeyypa0JaaGymaiabgUcaRmaakaaa baGabm4rayaaraWaaSbaaSqaaiabeo8aZbqabaGccqGHflY1caqGTb GaaeyBaaWcbeaakiabgwSixlaaigdacaaIWaWaaWbaaSqabeaacqGH sisldaqadaqaaiaadggadaWgaaadbaGaam4raaqabaWccqGHRaWkda WcaaqaaiaadkfadaWgaaadbaGaamyBaaqabaaaleaacaWGIbWaaSba aWqaaiaadEeaaeqaaSGaeyyXICTaaeytaiaabcfacaqGHbaaaaGaay jkaiaawMcaaaaaaaaa@68EB@
  • If   1  mm 1 < G ¯ σ 100  mm 1 n σ = 1 + G ¯ σ mm 4 10 ( a G + R m b G MPa ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaacaqGjb GaaeOzaiaabccacaqGGaGaaGymaiaabccacaqGTbGaaeyBamaaCaaa leqabaGaeyOeI0IaaGymaaaakiabgYda8iqadEeagaqeamaaBaaale aacqaHdpWCaeqaaOGaeyizImQaaGymaiaaicdacaaIWaGaaeiiaiaa b2gacaqGTbWaaWbaaSqabeaacqGHsislcaaIXaaaaaGcbaGaamOBam aaBaaaleaacqaHdpWCaeqaaOGaeyypa0JaaGymaiabgUcaRmaakeaa baGabm4rayaaraWaaSbaaSqaaiabeo8aZbqabaGccqGHflY1caqGTb GaaeyBaaWcbaGaaGinaaaakiabgwSixlaaigdacaaIWaWaaWbaaSqa beaacqGHsisldaqadaqaaiaadggadaWgaaadbaGaam4raaqabaWccq GHRaWkdaWcaaqaaiaadkfadaWgaaadbaGaamyBaaqabaaaleaacaWG IbWaaSbaaWqaaiaadEeaaeqaaSGaeyyXICTaaeytaiaabcfacaqGHb aaaaGaayjkaiaawMcaaaaaaaaa@69B1@
Table 1. Example values for Constants a G MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyamaaBa aaleaacaWGhbaabeaaaaa@37D5@ and b G MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyamaaBa aaleaacaWGhbaabeaaaaa@37D5@
Constants Stainless Steel Other steels GS GGG GT GG Wrought Al-Alloys Cast Al- Alloys
a G MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyamaaBa aaleaacaWGhbaabeaaaaa@37D5@ 0.40 0.50 0.25 0.05 -0.05 -0.05 0.05 -0.05
b G MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyamaaBa aaleaacaWGhbaabeaaaaa@37D5@ 2400 2700 2000 3200 3200 3200 850 3200
Where,
GS
Cast Steel and Heat Treatable cast steel for general purposes.
GGG
Nodular Cast Iron.
GT
Malleable Cast Iron.
GG
Cast Iron with lamellar graphite (grey cast iron).
R m MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaWGTbaabeaaaaa@37EC@ is UTS in MPa and dimension of G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ is mm. HyperLife takes care of the unit system for R m MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaWGTbaabeaaaaa@37EC@ and G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ through stress units defined in Material and stress unit and length unit defined in SN/eN dialog. a G MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyamaaBa aaleaacaWGhbaabeaaaaa@37D5@ and b G MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyamaaBa aaleaacaWGhbaabeaaaaa@37D5@ values are user input in Material under FKM Stress Gradient tab of My Material. Since the stress gradient has to be calculated in length dimension of mm, define the length units so that HyperLife can properly locate a point that is 1mm below the surface. If G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ is negative, n σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBamaaBa aaleaacqaHdpWCaeqaaaaa@38D9@ is set to 1.0. If G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ is greater than 100 mm-1, n σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBamaaBa aaleaacqaHdpWCaeqaaaaa@38D9@ is set to 1.0 with a warning message.
User-defined Relationship
User-defined relationship between n σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBamaaBa aaleaacqaHdpWCaeqaaaaa@38D9@ and G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ can be specified through a TABLE (pairs of (xi,yi) = ( G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ , n σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBamaaBa aaleaacqaHdpWCaeqaaaaa@38D9@ ) in My Materials. If G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ falls outside the range of xi, G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ will be extrapolated. This means that n σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBamaaBa aaleaacqaHdpWCaeqaaaaa@38D9@ can be lower than 1.0 when G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ is negative depending on how G σ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqaHdpWCaeqaaaaa@38B2@ is treated when being negative or greater than 100mm-1. The user-defined relationship takes precedence over the one in FKM guidelines.
