Add a Measure Group
Do one of the following:
  • From the Home tools, click the Measure tool.
    Then, from the Measure panel, click Add under the Measure Groups list.
  • Right-click in the Results Browser and select Create > Measure.
A new measure group with a default name is added to the list.
Tip: Use the Rename (right-click context menu) option to rename the new measure group if desired.
