Fit a Curve by Estimating UTS
An empirical formula can be used to estimate SN/EN data from ultimate tensile strength (UTS) and Young's modulus (E).
  1. From the Assign Material dialog, click the My Material tab and select your created material.
  2. Select Estimate from UTS as the input method.
  3. Click to view the model description.
  4. Enter a value for UTS and Elastic modulus.
  5. Click Estimate.
SN Properties
Figure 1. Estimated SN Data from Empirical formulae*
* Source: Yung-Li Lee, Jwo. Pan, Richard B. Hathaway and Mark E. Barekey. Fatigue testing and analysis: Theory and practice, Elsevier, 2005.
SRI1
Fatigue strength coefficient. It is the stress amplitude intercept of the SN curve at 1 cycle on a log-log scale.
b1
The first fatigue strength exponent. The slope of the first segment of the SN curve in log-log scale.
Nc1
In one-segment SN curves, this is the cycle limit of endurance (See Nc1 in Figure 2). In two-segment SN curves, this is the transition point (see Nc1 in Figure 4).
b2
The second fatigue strength exponent.
Empirically, the life of a metal is 1000 when the stress amplitude is approximately 90% of the UTS. (S1000 = 0.9UTS) when loading type is a bending load.
According to "Engineering Considerations of Stress, Strain, and Strength" by Juvinall RC, 1976, McGraw-Hill, fatigue limit (FL) can be estimated as follows:
  • For steel that has pearlite microstructure, FL = 0.38UTS at Nc1 = 1E6
  • For aluminum alloys whose UTS < 336MPa, FL = 0.4UTS at Nc1 = 5E8
  • For Aluminum Alloys whose UTS >= 336MPa, FL = 130MPa at Nc1 = 5E8
With the above information, two points on the SN curve are known: (1000, S1000) and (Nc1, FL). Thus, slope can be calculated:
b1 = (log(0.9UTS)  log(FL)) / (log(1000)  log(Nc1))
Once b1 is known, SRI1 is calculated by:
2S1000=SRI1(1000)b1
(The stress range 2*S1000 is used.) Therefore,
SRI1=2S1000/(1000b1)
Figure 2. One-segment SN curve in log-log scale (b2=0) (Nc1 is not defined or less conservative than FL)
Figure 3. One-Segment SN Curve in Log-Log Scale (b2=0) (FL is Not Defined or Less Conservative than Nc1)
Figure 4. Two-Segment SN Curve in Log-Log Scale
EN Properties
Figure 5. Estimated EN Data from UTS and E**
** Source: Anton Baumel and T. Seeger, Materials Data for Cyclic Loading, Elsevier, 1990
Sf/σf
b
Fatigue strength exponent.
c
Fatigue ductility exponent.
Ef/εf
Fatigue ductility coefficient.
Np/n
Cyclic strain-hardening exponent.
Kp/K
Cyclic strength coefficient.
Nc
Reversal limit of endurance. One cycle contains two reversals.
SEe
Standard Error of Log(elastic strain).
SEp
Standard Error of Log(plastic strain).
Figure 6. EN Curve in Log-Log Scale
