Configure Fatigue Analysis Using a Factor of Safety Calculation
Use the FOS tool to calculate fatigue based on a factor of safety value.
This approach uses the Dang Van method to calculate the multi-axial factor of safety.
Click the arrow next to the fatigue module icon and select the
FOS tool from the list of options.
Figure 1. The FOS dialog opens. - Select the FE model units.
- Select either Time Series or Transient Response as the loading type.
