ACU-T: 6500 Flow Through Porous Medium
Prerequisites
This tutorial provides the instructions for setting up, solving and viewing results for a simulation of a flow through porous medium. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 Basic Flow Set Up, and have a basic understanding of HyperMesh CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperMesh CFD and AcuSolve.
Problem Description
The problem to be addressed in this tutorial is shown schematically in the figure below. It consists of a cylindrical channel with a porous medium in the flow section. As the flow passes through this section, a pressure drop is observed. In this simulation, an inlet velocity will be assigned to the flow and pressure drop across the porous medium will be calculated. The length of the porous section is 0.06 m and the fluid is air with a density of 1.225 kg/m3 and a molecular viscosity of 1.781e-5 kg/m-s. The inlet velocity of the flow is 0.2 m/s.
In AcuSolve, a porous media problem can be solved using one of two methods: the superficial velocity method and physical velocity method. In this tutorial, we adopt the superficial velocity method, which provides good representation of the pressure drop through a porous media. However, it cannot predict the velocity increase in the porous region since the velocity in the porous region remains the same as those outside of the porous zones. The more accurate representation of velocity inside the porous region can be obtained using the physical velocity method, which solves the continuity and momentum equation inside the porous media using the intrinsic averaging method.
The pressure loss across the porous region using the superficial velocity method is modelled as:
where ΔP is the pressure drop (Pa) across the porous region, Δxi is the porous region length (m), k is the permeability, CD is the Darcy coefficient, Cp is the Forchheimer coefficient, μ is the viscosity (kg/m-sec), ρ is density (kg/m3), Vm is velocity magnitude (m/sec), and Vi is velocity (m/sec).
In this tutorial, you will utilize the porous coefficient calculator to calculate the Darcy coefficient and the Forchheimer coefficient after curve fitting of the array data of pressure drop vs velocity. The pressure drop across the porous region can be simplified as the permeability is not included in the curve fitting.
The Darcy coefficient CD and Forchheimer coefficient Cp are then calculated based on the curve fit coefficients
Figure 3. The Open File dialog opens. - Browse to the directory where you saved the model file. Select the HyperMesh file ACU-T6500_PorousMedia.hm and click Open.
- Click .
Create a new directory named PorousMedia and navigate into this directory.
- Enter PorousMedia as the file name for the database, or choose any name of your preference.
Validate the Geometry
Set Up Flow
Figure 5. The Setup dialog opens. -
- Set Time marching to Steady.
- Select Laminar as the Turbulence model.
Figure 6. - Click the Solver controls setting.
Confirm that the Steady update factor and the Steady maximum steps are set to
0.6 and 100,
respectively.
Figure 7.
Assign Material Properties
Figure 8. -
Verify that the material Air is assigned to the model's three solids.
Figure 9.
Define the Porous Medium
From the Flow ribbon, Porous
tool group, click the Cartesian Porous Media tool.
Figure 10. -
Select the middle solid on the model.
Figure 11. - On the guide bar, click Orientation.
- Left-click to place a point anywhere on the selected solid.
In the microdialog, click the coefficient calculator
and enter the following values for the coefficient calculator.
- porous zone thickness = 0.06 (m)
- air density = 1.225 kg/m3
- air viscosity = 1.781e-05 kg/m-sec
Figure 12. -
Close the coefficient calculator and confirm the values of the Darcy
coefficient and Forchheimer coefficient. Enter permeability values for the three
directions as shown in the figure below
Figure 13. -
to open the Orient tool then verify that the direction is aligned to the global x-axis.
Figure 14. -
to execute the command and exit the tool.
Assign the Flow Boundary Conditions
From the Flow ribbon, click the Constant tool.
Figure 15. -
Select the inlet face.
Figure 16. -
In the microdialog, set the velocity parameters as
shown below.
Figure 17. -
Click the Outlet tool.
Figure 18. -
Select the outlet face.
Figure 19. -
Accept the default parameters then click
on the guide bar.
Generate the Mesh
From the Mesh ribbon, click the
Volume tool.
Figure 20. The Meshing Operations dialog opens.Note: If the model has not been validated, you are prompted to create the simulation model before running the batch mesh. - Check that the Average element size is 0.01.
Accept all other default parameters.
Figure 21. -
Click Mesh.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: Right-click on the mesh job and select View log file to view a summary of the meshing process.
Run AcuSolve
Figure 22. - Set the Parallel processing option to Intel MPI.
Leave the remaining options as default and click
Run to launch AcuSolve.
Figure 23.
Post-Process with the Plot Tool
In the Run Status dialog, right-click on AcuSolve run and select Plot time
history to launch the Plot Manager.
Figure 24. -
Click
to create a new plot.
Click
under the Model panel to create a user defined function.
- In the Data Tree, expand pressure. then select
- In the Name field, enter dP.
- In the Value field, type value=.
Under Parts, choose AUTO Porous-1 SolidBody_2_1 internal
then click Insert Field to insert the field as part of
the value, as shown below.
Figure 25. - Type - at the end of the user defined function value.
- Under Parts, choose AUTO Porous-3 SolidBody_4_3 internal then click Insert Field to insert the field as part of the value.
Click
to add the user defined function.
Figure 26. -
Click the x axis to switch to Time Steps.
Figure 27. The pressure drop across the porous inlet (AUTO Porous-1 SolidBody_2_1 internal) and porous outlet (AUTO Porous-3 SolidBody_4_3 internal) surfaces is 0.0223 Pa.
Summary
In this tutorial, you learned how to set up and solve a flow simulation with porous medium. You started by importing the HyperMesh CFD input database and then you defined the porous medium. You also learned how to compute the Darcy and Forchheimer coefficients using the calculator available in HyperMesh CFD. Next, you assigned the flow boundary conditions and generated the mesh. Once the solution was computed, you created a plot of the pressure drop across the porous section using the Plot tool.
