ACU-T: 5101 Modeling of a Fan Component Using the Fan Component - PQ Method
Prerequisites
This simulation provides instructions for running a steady state simulation of flow inside a pipe with an interior fan placed at the middle of the pipe. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 Basic Flow Set Up, and have a basic understanding of HyperMesh CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperMesh CFD and AcuSolve.
Problem Description
The problem to be solved in this tutorial is shown schematically in the figure below. It consists of an interior fan which rotates at a speed of 377 rad/sec (~3600 RPM) and has a thickness of 0.06 m and a tip radius of 0.11 m. The volumetric flow rate at the inlet is 0.322675 m3/sec (~1212.3 m3/hr). The problem is simulated as a steady state run and the pressure rise across the fan region is computed.
Figure 2. The Open File dialog opens. - Browse to the directory where you saved the model file. Select the HyperMesh file ACU-T5101_PQ_FanComponent.hm and click Open.
- Click .
Create a new directory named PQ_Fan and navigate into this directory.
- Enter PQ_Fan as the file name for the database, or choose any name of your preference.
Validate the Geometry
Set Up Flow
Figure 4. The Setup dialog opens. -
- Verify that Time marching is set to Steady.
- Select Spalart-Allmaras as the Turbulence model.
Figure 5. -
Click the Solver controls setting and verify that the
parameters are set as shown in the figure below.
Figure 6. - Close the dialog and save the model.
Assign Material Properties
Figure 7. - Verify that the Air material has been assigned to all three volumes.
Click
on the guide bar to exit the tool.
Define the Fan Component
From the Flow ribbon, click the arrow next to the
Domain tool set, then select
Fan Component.
Figure 8. -
Select the middle solid as the fan component volume.
Figure 9. -
On the guide bar, click Surfaces
then select the face shown below as the inlet of the fan component.
Figure 10. -
From the View Controls toolbar, change the geometry visualization mode from
Shaded Geometry to Transparent Geometry.
This allows you to view the axis direction vector in the next step.
Figure 11. -
Axis.
In the modeling window, you can see that the axis points in the -X direction.
Click
in the microdialog to flip the axis vector to the +X direction.
Figure 12. -
Enter 0.06 for Thickness (m).
Figure 13. -
Click
beside P-Q Curve Type to open the Profile Editor.
Click
, browse to the location where you saved fanPQcurve.csv, and open it.
Figure 14. Note: Units for volume flow (Q) and Pressure Rise (P) are, respectively, m3/sec and Pa. -
to execute the command and exit the tool.
- Save the model.
From the Flow ribbon, Profiled
tool group, click the Volumetric Flow Rate tool.
Figure 15. -
Click the inlet face highlighted in the figure below.
Figure 16. -
In the microdialog, enter
0.322675 for the volumetric flow rate
(m3/sec).
Figure 17. -
Click the Outlet tool.
Figure 18. -
Select the face highlighted in the figure below and then click
on the guide bar.
Figure 19.
Generate the Mesh
From the Mesh ribbon, click the
Volume tool.
Figure 20. -
In the Meshing Operations dialog, set the Average element
size to 0.01 and the Mesh growth rate to
1.1 (if not set already).
Figure 21. -
Click Mesh.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: Right-click on the mesh job and select View log file to view a summary of the meshing process.
- Save the model.
Define Surface Monitors and Run AcuSolve
Set the entity selector to
Solids.
Figure 22. -
Select the fan component duct marked below to isolate it from front and aft
ducts.
Figure 23. -
Right-click and select Isolate form the context menu or
press I.
The solid for the fan component should be displayed in the modeling window.
Figure 24. -
Form the Solution ribbon, click the Surfaces tool.
Figure 25. -
Select the front face of the fan and verify that the arrow is heading toward
the fan component, as shown in figure below
Figure 26. -
to execute the command and remain in the tool.
- In the legend, rename surface_output to FAN_inlet.
Rotate the fan component and select the rear face.
Figure 27. -
Click
, rename surface_output to FAN_outlet in the legend, then click
to exit the tool.
Figure 28. The Launch AcuSolve dialog opens. - Set the Parallel processing option to Intel MPI.
Leave the remaining options as default and click
Run to launch AcuSolve.
Figure 29.
Post-Process with the Plot Tool
From the Solution ribbon, click the Plot tool.
Figure 30. Figure 31. -
Click
to create a new plot.
- In the Data Tree, expand pressure. then select
Under Parts, select Fan_inlet and
Fan_oultet to display pressure at the inlet and
outlet.
Figure 32. - Right-click User Defined under the Model panel to create a user defined function.
- In the Name field, enter dP.
- In the Value field, type value=.
Under Parts, choose FAN outlet then click
Insert Field to insert the field as part of the
value, as shown below.
Figure 33. - Type - at the end of the user defined function value.
- Under Parts, choose FAN inlet then click Insert Field to insert the field as part of the value.
Click
to add the user defined function.
Figure 34. -
Click the x axis to switch to Time Steps.
Figure 35. From the above figure, the pressure got stabilized at around the 6th iteration and remains constant with pressure difference between the FAN_inlet and FAN_outlet of 423.97 Pa for a given volume flow rate 0.322675 m3/sec, which is very near compared to the reference pressure increase of 424.9 Pa.
Summary
In this tutorial, you successfully learned how to set up and solve a simulation involving a PQ fan component using HyperMesh CFD. You imported the geometry and then defined the simulation parameters, fan component, and flow boundary conditions. Once the solution was computed, you used the HM-CFD Plot tool to plot the pressure at fan inlet and fan outlet.
