Patch and Delete Surfaces
Use the Surfaces: Patch tool to create patch surfaces between free lines that are not connected or surface edges. You can also delete surfaces with this tool.
From the Geometry ribbon, click the tool.
Figure 1. -
To manually patch surfaces, do one of the following:
- While left-clicking, drag an edge to another edge.
Hovering over a target line displays a preview surface.
- Select multiple edges around a missing surface, then click an edge that has already been selected.
- Select multiple edges or loops, then click Patch All on the guide bar.
- Double-click an edge loop.
Tip: After a patch surface has been manually created, it remains selected. HyperMesh CFD attempts to select the appropriate tangency setting for the surface created, but you can change the tangency by clicking on the surface while it is still selected. - While left-clicking, drag an edge to another edge.
To automatically highlight and patch missing surfaces:
- Click Find on the guide bar.
Click
and
to cycle through found surfaces.
- Select highlighted surfaces to fix them individually or click Patch All on the guide bar.
- Check Create mesh to automatically open the 2D meshing tool after creating surfaces. After you finish meshing, exit the tool to return to Geometry.
To delete surfaces:
- Select the surface(s) you want to delete.
- Click the highlighted surface(s) again to delete them.
Patch Surfaces Using the Context Menu
Quickly patch surface holes without opening the Surfaces: Patch tool.
- Navigate to the Geometry ribbon.
- While in idle mode, select the surfaces to patch.
- Right-click in the modeling window and select from the context menu.
