HyperLife
HyperLife 2024 introduces a new license feature,
HyperLifeSolver, that follows the solver licensing scheme
for InApp- and HPC-based evaluation. The Altair unit draw
depends on the number of CPU cores assigned to the HyperLife
job. The HyperLife Solver license feature is required for
Stress Life, ERRI, and IEC evaluation in HyperLife Weld
Certification. HyperLife sessions for setting up workflows
will continue to use the license feature - HyperLife.
HyperLife 2024 requires you to install the HyperWorks
Desktop and Solver packages. Installing HyperLife via
Solvers is a prerequisite for Stress Life, ERRI, and IEC
fatigue evaluation using HyperLife Weld Certification.
HyperMesh CFD
HyperMesh CFD 2024 introduces the new license feature,
InspireGeometry. This feature is required when accessing the
Solid Modeler and PolyNurbs ribbons in the Case Setup
environment.
Flux
Flux 2024 introduces the new license feature,
FluxPEECSolver. This feature is required to run the
Parasitic Extraction solver in Flux for one core. Multi-core
usage follows the Solver In-App Licensing table.
FluxMotor
FluxMotor 2024 introduces the new license feature,
FluxMotorFSSolver. This feature is required to run the Flow
Simulator Solver in FluxMotor. It takes 21 AUs to run the
first instance. It levels on the first instance and stacks
on the second instance and onward.
Simlab
SimLab 2024 introduces the new license feature,
SimLabFluxPEECSolver. This feature is required to run the
Parasitic Extraction solver in SimLab for one core.
Multi-core usage follows the Solver In-App Licensing
table.
