NFX-T: 1000 Simple Single Phase Gearbox
Set up a simple single phase gearbox for drive train oiling simulation using SimLab for CFD-nanoFluidX solution. Oil distribution will be analyzed and basics of the post-processing in SimLab will be demonstrated.
Note: A PDF version of this tutorial is available in the Model Files section.
In this lesson you will learn how to:
  • Select Unit System
  • Import CAD Geometry
  • Define SPH Flow Solution
  • Define Oil properties
  • Define Initial Conditions
  • Define Body Force
  • Assign Motion
  • Create SPH Particles
  • Set Solver Settings
  • Set Result Request
  • Check Simulation Data
  • Perform Basic Post-processing in SimLab
Prerequisites
To run this simulation, you will need access to a licensed version of SimLab and nanoFluidX.
Model Files
Before you begin, copy the file(s) used in this tutorial to your working directory.
Tutorial Video
Additional Resources
For more tutorials, visit the SimLab Learning Center.
