Multiphase Flow of a 2D Dam Break
In this application, AcuSolve is used to simulate the collapse of a water column surrounded by air. AcuSolve results are compared with experimental results adapted from Rodriguez and others (2013). The close agreement of AcuSolve results with experimental results validates the ability of AcuSolve to model multiphase flow problems.
Problem Description
The problem consists of a column of water being held in place by a membrane in a box of air, as shown in the following image, which is not drawn to scale, where a = 0.05715 m. At t = 0, the membrane is broken, allowing the water column to collapse.
Figure 1. Critical Dimensions and Parameters for Simulating a 2D Dam Break Problem
Figure 2. Mesh used for Simulating Multiphase Flow of a 2D Dam Break Problem
AcuSolve Results
The AcuSolve solution is run for a time t = 0.4 sec and the results reflect the transient motion of water column.
Figure 3.
The experimental values of normalized surge front positions (x/a) and normalized column height (y/a) is presented below with the corresponding AcuSolve results. The AcuSolve results show good agreement with the experimental results.
Figure 4. Surge Front Position and Column Height Compared to Experimental Results for Simulating Multiphase Flow of a 2D Dam Break
Summary
The AcuSolve solution compares well with experimental results for a dam break problem. In this application, multiphase flow simulation of the collapse of a water column is performed. The experimental value for the normalized column height and normalized surge front positions is presented with the corresponding AcuSolve results. A good agreement of simulation results with the experiment validates the multiphase capability of AcuSolve.
Simulation Settings for Multiphase Flow of a 2D Dam Break
HyperMesh CFD database file: <your working directory>\dambreak_multiphase\damnbreak_multiphase.hm
Global
  • Problem Description
    • Analysis type - Transient
    • Multifluid - Level Set
    • Gravitational acceleration - { 0, -9.81, 0 }
  • Auto Solution Strategy
    • Final Time - 0.4 sec
    • Initial time increment - 0.0005 sec
    • Fluid 1 - Water
    • Fluid 2 - Air
  • Time Integration
    • Time integration order – “second”
  • Material Model
    • Air
      • Type - Constant
      • Density - 1.2 kg/m3
      • Viscosity - 1.1818e-006 kg/m-sec
    • Water
      • Type - Constant
      • Density - 1000 kg/m3
      • Viscosity - 0.001 kg/m-sec
  • Multifield Parameters → Field Interaction Model
    • Field 1 - Water
    • Field 2 - Air
    • Thickness type - Number of elements
    • Number of elements - 3
    • Fluid 2 - Air
    Model
  • Volumes
    • Fluid
      • Element Set
        • Medium - Multi Field
        • Multi field model - Water-Air
  • Surfaces
    • +Z
      • Simple Boundary Condition - Slip
    • -Z
    • Bottom wall
      • Simple Boundary Condition - Wall
    • Left wall
    • Right wall
    • Top wall
References
Joseph M. Rodriguez, Onkar Sahni, Richard T. Lahey Jr., Kenneth E. Jansen. "A parallel adaptive mesh method for the numerical simulation of multiphase flows", Computers and Fluids, Vol. 87, 2013, pp. 115-131.
