Magnetic Modelling
The magnetic properties of the dielectric is defined.
Non-Magnetic
The relative permeability ( μr ) is set to 1.0 and the magnetic loss tangent ( tanδu ) is set to 0.0.
Frequency Independent
The media is defined in terms of the relative permeability ( μr ) and the magnetic loss tangent ( tanδu ).
The effective permeability of the dielectric is given by:
μeff=μ0μr(1jtanδμ)
Frequency List (Linear Interpolation)
The dielectric properties of the material are defined at various frequency points. Values for the dielectric properties are then linearly interpolated to obtain the dielectric properties at frequency points other than specified.
Data points at a range of frequencies are specified. Values for the dielectric properties are then linearly interpolated to obtain the dielectric properties at frequency points other than specified. Parameters required are frequency, relative permeability ( μr ) and the magnetic loss tangent ( tanδu ).
