Creating a Package Configuration File
Specify the settings to control the simulation and queueing process.
Launch QUEUEFEKO.
Figure 1. The component, QUEUEFEKO. -
Click
Figure 2. The New package configuration dialog. - In the Base file field, select the base .pre file or .cfx file.
In the Launch component field, select one of the
following:
- To run the Solver, select Solver.
- To do an optimisation, select OPTFEKO.
- In the Number of parallel processes field, enter the number of parallel processes allocated on the local machine.
- In the Maximum RAM per process field, enter the maximum number of allowed RAM to be used on the cluster machine.
- In the Maximum wall clock time field, enter the maximum allocated time to run the simulation on the cluster machine.
- Click OK to close the dialog.
