[5] Using Altair Panopticon Streams
Connecting to or Disconnecting from the CEP Engine
NOTE |
Panopticon Streams Server will be connected to the CEP engine after start up if any of the following settings is true: · The default setting of the localhost for the Kafka broker is available. · The Kafka settings in the Streams.properties file are correct. |
Click Kafka Connection Status to expand and display the Engine pane and view the settings.
For
For
Property |
Description |
Status |
Displays whether Panopticon Streams is connected to or disconnected from the CEP Engine (Kafka). |
Type |
The CEP Engine that Panopticon Streams engine will work with (KAFKA). |
ZooKeeper |
The URL to the ZooKeeper servers. Default is localhost:2181. |
Kafka |
The URL of all the Kafka servers. Default is localhost:9092. |
Schema Registry |
The URL to the Schema Registry. Default is http://localhost:8081. |
