Altair® Panopticon™
Creating Kx kdb+ Output Connector
Allows periodical dumping of records from a Kafka topic into a Kx kdb+ connector.
1.     On the Data Source tab, select Output > Kdb+ in the Connector drop-down list.
2.     Define or select the following properties:
Property
Host
Kx kdb+ host address.
Port
Kx kdb+ host port. Default is 5001.
TLS Enabled
Ensure to check if you have started q with TLS only.
User Id
The user Id that will be used to connect to Kx kdb+.
Password
The password that will be used to connect to Kx kdb+.
Table
The source table.
   NOTE
These properties can be parameterized.
3.    You may opt to use the toolbar to complete the data source definition.
4.     Click . The new data source is added in the Data Sources list.
