Altair® Panopticon™
Using the Data Source Toolbar
Several data sources have a toolbar:
Click on any of the following icons:
Icon
A new column entry displays. Enter or select the following properties:
·         Source
·         Target
The column name of the target schema.
·         Type
The data type of the column. Can be a Text, Numeric, or Time.
Check the topmost  to select all data source column entries.
Check the  of a data source entry or check the topmost  to select all column entries and click  to delete.
Allows you to select an output topic in the drop-down list.
Click OK. The schema of the selected output topic is displayed.
Tests if the connection to the output connector is successful.
If successful, a confirmation message displays.
Click OK.
Otherwise, an error prompt displays.
Click Close and fix the connection error.
