Assigning Privileges
When you grant privileges to roles, user groups or users, you specify which actions the role members, group members or users can perform within Monarch Server.
The following privileges can be granted:
  • Common Privileges
  • Administrator: Allows users to log on to MSAdmin.
  • Report Warehouse Privileges
    • Document search: Allows users to configure searches.
    • Save search: Allows users to save searches that they created.
    • Report search: Allows users to search and view original reports.
    • Delete document: Allows users to delete documents from the report warehouse.
    • Download Original Report: Allows users to download the archive copy of reports.
    • Concatenate Original Reports: Allows users to download a number of original PDF reports as a single file.
    • Create annotation: Allows users to create annotations.
    • Create notification: Allows users to create search notifications and filing notifications.
    • See trustee list on save Annotation: Allows the user to view the list of trustees in the saved annotation report.
    • See trustee list on save Search: Allows the user to view the list of trustees in the saved search.
    • Add attachments on Annotations: Allows the user to add attachments to the annotation report.
    • Create Annotations for all users: Allows the user to create an annotation report accessible to all users.
    • Edit and delete Annotations: Allows the user to modify and remove annotations.
    • See Annotations: Allows the user to view the existing annotations.
  • Automator Privileges
    • Automator Administrator: Allows the user full administration.
    • Automator User: Allows the user to manage processes and jobs.
      • Can Edit Scripts: Allows the user to edit process scripts and script items for Visual Processes and Standard Processes, as well as project scripts (i.e., PreProcess, PostProcess, and Global). If unselected, the user cannot edit the properties of script items for existing processes; the user can only run the script and check the results.
    • Automator Light User: Allows the user to partially manage processes and jobs.
      • Can Edit Schedules: Allows the user to add, edit, and delete schedules for Visual Processes and Standard Processes. Note that only the schedules whose processes are assigned to the user can be modified.
  • RMS Privileges
    • RMS User: Allows the user to connect to RMS Client.
    • RMS Administrator: Provides the user with full administration rights to Monarch Server Report Mining Edition.
To grant privileges
  1. On the Navigation Tree, click Rights and Privileges, and select Roles, User Groups or Users (depending on who you want to assign privileges to).
  2. Click the name of a role, user group or user by clicking anywhere on the row, and then click .
  3. In the Privileges section, select the necessary check boxes to specify the privileges for the role, user group, or user.
  4. Click Save to save the current settings.
