Adding a Filing Notification
To add a filing notification
On the Navigation Tree, click Report Warehouse, then click Document Retrieval and select Filing Notifications.
Click
on the Filing Notifications page. The Filing Notification page appears. -
Filing Notification Name: Enter a unique name of a new notification.
Filing Description:Optionally, enter any text defining the filing notification
Document Groups: Select a document group that contains the document type you want to apply the notification to.
Document Types: Select the document types to be included in the filing notification definition.
Run immediate: Select this check box to execute the filing notification immediately upon the filing completion event. Each filing notification will be sent as an individual e-mail.
Execution Frequency: These options become available if you have not selected the Run immediate check box. You can set the frequency of executing filing notifications.
To save a new or existing filing notification definition, click the Save button.
To reset the values, click the Clear button.
Save: Saves a new or existing filing notification definition.
To close the Filing Notification page without saving, click Cancel. Keep in mind that no changes will be saved.
NOTE: You can assign a notification to a role, user group or user via the Rights tab, which is available only for existing search notifications. For more details see Editing a Filing Notification.
