*ELEMENT_MASS
LS-DYNA Input Interface KeywordThis keyword defines mass added to nodes or node sets.
*ELEMENT_MASS_{OPTION}
EID NID or set_ID MASS
Definition
OPTION Mass distribution option.
= <blank>
The defined mass is applied to the node identifier NID.
= NODE_SET
Mass is distributed uniformly among a set of nodes defined by set_ID.
EID Element identifier.
(Integer)
NID Node identifier.
(Integer)
set_ID Node set identifier.
(Integer)
Mass Mass.
(Real)
[ kg ]
  1. This keyword maps to /ADMAS.
