AESYMXY
I/O Options and Subcase Information Entry Aerodynamic XY plane of symmetry flag. The AESYMXY command can be used in the case control section to indicate whether the aerodynamic model has symmetry with respect to the ground.
AESYMXY = option
| Argument | Options | Description |
| option | <SYMMETRIC,
ANTISYMMETRIC,
ASYMMETRIC> Default: See Comments |
- If AESYMXY is not present in case control, aerodynamic XY symmetry will be determined from the SYMXY field of the AEROS Bulk Data Entry for static aeroelastic analysis.
- If AESYMXY is present above the subcase level, it is applied to all subcases until overridden.
