MAT4
Material Property ElementMAT4 lets you define a hyper-elastic material model for NLFE elements based on the Mooney-Rivlin material model.
<MAT4
       id       = "integer"
       mu01     = "real"
       mu10     = "real"
       nu       = "real"
       rho      = "real"
       YS       = "real"
/> Attributes
- id
 - Unique material property identification number.
 - mu01
 - Material constant ( ).
 - mu10
 - nu
 - Poisson's ratio for the element. Default is 0.49.
 - rho
 - Element density.
 - YS
 - An elastic limit for strain. Default is 0.0.
The example demonstrates the definition of a MAT4 element.
<MAT4 id="1" mu01="8e+3"  mu10="2e+3" nu="0.499" rho="7.810e-6" YS="0.125"/>
- This material element defines a hyper-elastic material that
                            follows the Mooney-Rivlin material model law for the strain energy
                            density function:
where
is the shear modulus
is the bulk modulus
is the Poisson's ratio
Each element must have a unique material identification number.
 - This material model can only be used with a fully parameterized element (BEAM12, QUAD12, TRIA12 and solid elements).
 - mu10 and mu10 are material constants. mu10 can be determined using a tension or compression tests, however, mu01 should be determined using a biaxial test.
 - YS lets you specify a maximum limit on the elastic strain that the component is allowed. If, during the simulation, the component strain (at any element in the component) exceeds this value, MotionSolve issues a warning message.
