GET_SPARSE_MATRIX_DATA
Utility/Data Access SubroutineReturns the data from a sparse Reference_Matrix element.
Use
The function can be called by any user subroutine. There is a separate function for a full Reference_Matrix element called GET_FULL_MATRIX_DATA.
- Fortran Calling Syntax
 - CALL GET_SPARSE_MATRIX_DATA(id, rows, cols, vals, size, ierr)
 - C/C++ Calling Syntax
 - c_get_sparse_matrix_data(id, rows, cols, vals, size, ierr)
 - Python Calling Syntax
 - [rows, cols, vals, ierr] = py_get_sparse_matrix_data(id, size)
 - MATLAB Calling Syntax
 - [rows, cols, vals, ierr] = m_get_sparse_matrix_data(id, size)
Attributes
- id
 - [integer]
 - size
 - [integer]
Output
- rows
 - [integer]
 - cols
 - [integer]
 - vals
 - [double precision]
 - ierr
 - [integer]
