FLEX_BODY
Command ElementModifies the FLEX_BODY modeling element.
FLEX_BODY/30102, H3D_FILE=../../flex_h3d/Cadre.h3dFormat
FLEX_BODY/id, [ CRATIO={e, USER(r1[,…,r30> ] [,LIST]
H3D_FILE=filenameArguments
- CRATIO
 - Redefines the damping ratio using an expression or the user defined subroutine DMPSUB. The CRATIO must be either the last argument or followed by a backslash (\).
 - H3D_FILE
 - Name of the file containing the CMS results.
 - ID
 - Identifier of the flexible body element.
 - LIST
 - Lists the flexible body arguments.
The argument H3D_FILE is the only addition to the standard ADAMS arguments. It is necessary to specify the CMS results file for MotionSolve.
