The BISTOP function models a gap element.
      It can be used to model forces acting on a body while moving in the gap between two
        boundary surfaces, which act as elastic bumpers. The properties of the two boundary surfaces
        can be tuned as desired.
    Arguments
          - The expression used for the independent variable. For example, to use the
            z-displacement of I marker with respect to J
            marker as resolved in the reference frame of the RM marker as the
            independent variable, specify
                         as DZ({marker_i.idstring},
              {marker_j.idstring},
            {marker_rm.idstring}).
          - The time derivative of the independent variable. For example, if
                         is specified as above, then
                         will be VZ({marker_i.idstring},
              {marker_j. idstring},
          - The lower bound of
                        . If
                         is less than
                        , the bistop function returns a positive value.
            The value of
                         must be less than the value of
          - The upper bound of
                        . If
                         is greater than
                        , the bistop function returns a negative value.
            The value of
                         must be greater than the value of
          - The stiffness of the boundary surface interaction. It must be non-negative.
          - The exponent of the force deformation characteristic. For a stiffening spring
            characteristic,
                         must be greater than 1.0 and for a softening spring
            characteristic,
                         must be less than 1.0. It must always be positive.
          - The maximum damping coefficient. It must be non-negative.
          - The penetration at which the full damping coefficient is applied. It must be
            positive.
Definition
      (1)
      <Force_Vector_TwoBody
     id                    = "30101"
     type                  = "ForceOnly"
     i_marker_id           = "30102031"
     j_floating_marker_id  = "30101031"
     ref_marker_id         = "30101010"
     fx_expression         = "BISTOP(DX(30102030,30101010,30101010),VX(30102030,30101010,30101010),0.5,9.5,10000000,2.1,1,0.001)"
     fy_expression         = "0"
     fz_expression         = "0"
