Altair HyperLife Weld Certification 2023 Release Notes
New Features
- Ribbon Hints
- Ribbon hints have been added to help identify tools that have multiple
pick targets or open a secondary ribbon. They are small indicators that
appear in the ribbon between a tool’s icon and label. The number of dots
represents the number of pick targets in a tool, including some that are
hidden until hovering over the tool.Figure 1.
Resolved Issues
- Application error while evaluating specific models.
- Inconsistent behavior of the Load Combination File (LCF) when running more than one step/increment.
- Derived subcase IDs created from LCF being blocked upon delete.
- Shear utilization in FKM unwelded evaluation.
- Stress projection in solid weld evaluation.
Known Issues
The following known issues will be addressed in the upcoming release as we
continuously improve the performance of the software:
- Weld detection with Abaqus part instances.
- Load map issue when derived load cases and original load cases have the same IDs. A load combination file is encouraged in such scenarios.
- The progress bar is not shown for weld detection, applying regulation and evaluation operations. The issue is specific to the Linux operating system.
- Inconsistent behavior in evaluating B-welds with IEC specification.
