Exterior Noise - Load
Load an H3D or PCH results file and plot a response for the Sound Pressure result, calculated using the APML or IE method.
Plot a Response for Sound Pressure
- From the Radiated Sound > Exterior Noise > Load tab, load the result file to view and load the model.
- Make a selection from the Subcase drop-down menu.
- The Result type is listed as Pressure.
For the Result component, select the microphone location:
- Select a node from the list.
Click Load Response to plot the response. It is
possible to plot the response in linear frequency scale or
octaves.
The utility automatically switches to the Display tab.
If you select Sound Pressure for the result type:
- For Result set, select Sound Pressure or Power from Pressure.
- For Receiving Panels, select a set that corresponds to particular source nodes. This can be used for panel participation.
For Result component, select the microphone location:
- Select a node from list
- Select the microphone location from model
