There are several files in the HyperForm installation that are used for storing settings related to the type of manufacturing simulation setup. These files are:
In the <install_directory>\hm\scripts\hyperform\automation directory:
File |
Description  |
process_defaults.dat  |
Contains default values for the velocities and binder force that appear under Setup in the Auto Process macro in addition to other process parameters.  |
settings.dat  |
Used to customize your setup while using the Multi-stage Manager and the Auto Process macros.  |
lsdyna.bat  |
Contains the location of the LS-DYNA solver executable.  |
In the <install_directory>\hm\scripts\hyperform\hydroform directory
CTRL-ALT-P
File |
Description  |
HydroformInitDefaults.dat  |
Contains the default recommended tool velocities and pressures used for hydroforming.  |
tubeBendingInitDefaults.dat  |
Contains default parameters related to the form tool location, rotational velocity, and rigid mass parameters recommended for tube bending.  |
