HyperForm file types follow the standard naming convention: partname.suffix. The suffix indicates the type of information contained in the file. HyperForm recognizes the following file types:
.hf  |
HyperForm model file  |
.parm  |
HyperForm input deck  |
.out  |
Model and run information  |
.dat  |
Input data summary  |
.err  |
Error file  |
.res  |
Results files  |
_thk.nas  |
Nastran deck with stamped thickness distribution  |
_dyna.k  |
HyperForm output for DYNA analysis  |
opt.dat  |
Input deck for optimization runs  |
0000.rad  |
HyperForm output for RADIOSS analysis  |
0001.rad  |
.up  |
User process data file  |
| Note: | You must have write privileges in the working directory before modifying these files. |
