Settings Option
DefaultProcess
Name of the process to display if the process contains no data.
AutoPosTol
(Auto Positioning Tolerence)
Lets you specify two values: 0 to Disable or 1 to Enable. Enable moves the tools during auto positioning to get roundoff numbers. This option is valid only for Auto Process.
AutoCompNames
Lets you specify two values: 0 to Disable or 1 to Enable. Components are set based on the pattern below for each tool object:
| • | Die Pattern: Default string: die* |
 | • | Punch Pattern: Default string: punch* |
 | • | Blank Pattern: Default string: blank* |
 | • | Binder Pattern: Default string: binder* |
 | • | Support Pattern: Default string: support* or pad* |
 | • | UpperBinder Pattern: Default string: upper* |
 | • | LowerBinder Pattern: Default string: lower* |
 | • | WiperPattern: Default string: wiper* |
CurveIntegration
Lets you specify two values: 0 to Disable or 1 to Enable. The Disable curve area is located in the details page of the AutoProcess. Default: 1.
CloseConfirmation,Setup
Asks for confirmation when you click Close in the setup page. Three options are available: 0: Never ask; 1: Ask if you have changed a value but have not clicked Apply; and 2: Always ask. Default: 0.
CloseConfirmation,Drawbeads
Asks for confirmation when you click Close in the setup Drawbead editor dialog. Three options are available: 0: Never ask; 1: Ask if you have changed a value but have not clicked Apply; and 2: Always ask. Default: 0.
CloseConfirmation,Details
Details
Displays the details page in Auto Process. Three options are available: 0: Hide; 1: Partial display; and 2: Full display. Default: 1.
UserMaterialPath
Points to the directory where the materials you created are stored.
MaterialDatabase
Points to the location of the material database that is included with the HyperForm installation.
RADIOSS_ARGUMENTS
Arguments to be passed on for the solver run. Defaults:
| • | –both : Run both starter and Engine |
 | • | –noh3d : Don’t generate h3d file after solver run |
 | • | –nproc : Sets number processors for the solver run. Default = 1. |
RADIOSS_PC
Points to the location of the RADIOSS solver launch script that is included with the HyperForm installation for the Windows platform.
RADIOSS_UNIX
Points to the location of the RADIOSS solver launch script that is included with the HyperForm installation for the Linux platform.
SymmetryTolerance
Specifies Tolerance to identify nodes that define constraints based on the symmetry plane definition in the User Process and Auto Process.
DistanceCalc
Specifies the method for distance calculation in the User process and Auto Process. Lets you specify two values: 1: Old method; 2: New method. Default value: 2.
Drawbeads
Option to turn On and Off the Drawbead editor from the Auto Process. Lets you specify two values: 1: Enabled; 0: Disabled. Default value: 1.
WindowGeometry
Applies default window geometry size and location: 640x520+0-30.
MSM_Autoposition
Enables or disables the Autoposition option in the Multistage manager. Lets you specify two values: 1: Enabled; 0: Disabled. Default value: 1.
DB_DoNotProjectLines
Does not to project the drawbead lines on the target tool. Lets you specify two values: 1: Enabled; 0: Disabled. Default value: 0.
AutopositionConfirm
Asks for confirmation before performing the Autoposition option in the User Process. Lets you specify two values: 0: No; 1: Yes. Default value: 1.
AutoprocessWindow
Displays Auto Process. Two display options are available: Panel or Window. Default: Panel.
MultistageWindow
Option to display Multistage manager process. Two display options are available: Panel or Window. Default: Panel.
UserProcessDirectory
Lets you specify the directory to store the User process templates. By default, the directory is empty.
