HyperForm Settings are organized into two groups of options known as global settings and process defaults. These options are specific to each user profile.
To access HyperForm Settings, select Preferences > HyperForm Settings. A dialog appears with the options set for the current user profile. The following image shows the dialog for the RADIOSS user profile:
Left-click File and a menu opens with the following options:
Option  |
Description  |
Open |
Opens an existing processdefaults.dat or settings.dat file.  |
Save |
Saves the current settings as a processdefaults.dat or settings.dat file in the My Documents folder.  |
Save As... |
Saves the current settings as a processdefaults.dat or settings.dat file in the folder you select.  |
Save In Home |
Saves the current settings as a processdefaults.dat or settings.dat file in the HyperForm home directory.  |
The HyperForm Settins dialog includes a Solver dropdown menu from which you can select one the following solvers:
| • | LS-DYNA |
| • | RADIOSS |
| • | RADIOSS One Step |
| • | Die Module |
The options on the Settings tab and ProcessDefaults tab are specific to each user profile. Click the following links to view the options for each profile:
These are general options available for each user profile:
Option  |
Description  |
Default  |
Restores a current setting to its default value.  |
Apply  |
Applies setting changes to the current session, but does not save the settings.  |
Close  |
Closes the dialog.  |
