The Moldex3D Solid Utility menu consists of buttons that provide shortcuts to different functions. The layout of the buttons mimic the process flow required to set up a model for Moldex3D Solid.
The main Utility menu is shown below, along with descriptions of function.
Surfaces |
Cleanup |
Shortcut to the Edge Edit panel. This shortcut provides quick access to the Edge Edit, Defeature, and Point Edit panels for geometry cleanup operations.  |
Midsurface |
Shortcut to the Midsurface panel, which provides tools to extract a midsurface from selected surfaces.  |
Lines |
Create |
Shortcut to the Lines panel, which is used to create lines.  |
Edit |
Shortcut to the Line Edit panel, which is used to edit lines.  |
Extract Axis |
Opens the Extract Axis dialog, which extracts the axis of the given solid. See Extract Axis for more details.  |
Generate Mesh |
Coolant Channel Line |
Opens the panel to generate 1D beam mesh for the coolant channel.  |
Surface Mesh |
Opens the size and bias subpanel of General 2D Meshing, which is used to create tria3 elements on surfaces.  |
Layered Tet Mesh |
Opens a submenu of macros for generating a layered CFD solid mesh. See Layered Tet Mesh Submenu.  |
Solid Meshing Wizard |
Opens the Solid Meshing Wizard, which facilitates meshing the solids either with solidmap, tetmesh or CFD mesh.  |
Runner Meshing Wizard |
Opens the Runner Meshing Wizard, which contains a dialogs that help create a high quality solid mesh for the runner system consisting of prism and tetrahedral elements. See Runner Meshing Wizard.  |
Moldex3D Wizard |
Opens the Moldex3D Wizard tab, which contains a step-by-step procedure to set up an Boundary Layer 3D Mesh See Moldex3D Wizard.  |
Model Setup  |
Create Property Cards |
Opens a submenu for setting up the model. See Create Property Cards for details.  |
Diagnostics |
Computes the element quality of the displayed solid elements.  |
Export |
Opens the Moldex3D MFE Export dialog for exporting the model. See Export for details.  |
