Prefix All Curves with an Iteration Identifier
- To display the Parameters Browser, click View > Parameter Browser in any client beside HyperMesh.
                Right-click within the white space of the browser and
                    select Expand All.
                The browser is expanded to show the entire contents of the session.
 - Right-click on a curve and select Select All from the context menu.
                Activate the checkbox next to Name.
                A new row is added to the lower portion of the parameter table.
                Click the ellipse button,
, next to the default curve name to display the
                        More Options dialog.
             - In the Name field, enter Run ID:.
 - Change Value type to Prefix.
 - Change Default value to Run 1.
 - Click OK.
                Click Save,
, to save
                    the script template.
             - Click OK.
 - Click File > Session > Flexible Reports to display the Flexible Report Templates dialog.
 - In the Run ID field, enter Run 2.
                Click Apply.
                The session is recreated and all curve names have Run 2 at the start of their name.
